My JZX90 was sold a few months ago but I really didn't have much time to browse through the site to sell the set.
The shocks look really slightly used.
I would like to sell them for 400NZD.
The set is located in the North Shore of Auckland.
PM me if you're interested.
>I will add photos ASAP.
JZX90/JZX100 TRD Springs + Shocks
1993 トヨタ クレスタ TOURER S JZX90
Re: JZX90/JZX100 TRD Springs + Shocks
do you know how much of a drop they give if at all?
driftouteast
I have trd springs on standard shocks, its not super low but you can notice the difference
I agree. The spring rates are higher than your average aftermarket springs. plus it does have a few unsprung coils (2 or 3 I think) which you can cut for height preference without stiffening or increasing the spring rate.driftouteast wrote:I have trd springs on standard shocks, its not super low but you can notice the difference
The real treat is the improvement in handling.
only reason i ask is cause i have a friend after some mine is sacked (talking 95-100mm off the ground) so illl see if he is keen
mine has just got super lows in it and its siting at 55mm off the ground........weird
