General Specifications
•8 Injector Drivers
•8 Ignition Drivers
•8 General Purpose Output Drivers
•9 Analog Inputs
•5 Digital Inputs.
•Magnetic or Hall Cam and Crank Input
•High RF suppression.
•Temperature range -40 to 85 Celsius.
•Operating voltage 6 – 25 Volts.
Computer Software
•Real-time online tuning
•Tune Analyzer.
•Auto Tune.
•Data logging and analysis software.
Ignition
•Full Sequential ign (coil-on-plug)
•Directly connect to most OEM ignition systems
•Timing accuracy / resolution 0.2 degrees
•Dual 48X32 user definable tune maps.
Injection
•Full 720 degree sequential injection timing.
•Automatic Staged injection activation
Trigger Sensors
•Compatible with most OEM trigger systems.
•Magnetic, hall or optical cam & crank inputs.
•Automatic magnetic sensors calibration.
•Selectable trigger patterns for most engine manufacturers.
Input Sensors
•5 Standard inputs
•1 Barometric pressure input.
•8 programmable voltage inputs.
•5 programmable digital inputs.
•2 Wide band lambda inputs
Output Drivers
•8 User programmable output channels.
•4 Selectable PWM / Digital. e.g. boost control.
4 Digital. e.g. thermo fans, fuel pump.
•Dedicated stepper motor output. e.g. idle control.
Special Functions
•Programmable engine protection system.
•Closed loop idle control.
•Closed Loop lambda control.
•Gear change ignition cut.
•Dual mode turbo anti lag (Drag or Rally).
•Dual mode RPM Limit (hard and soft).
•Two-Step rev limiter.
•Nitrous oxide control.
•Engine load idle-up control. (air con, power steering)
•Programmable sensor calibration tables.
•Barometric compensation.
•Selectable tune map via any digital input.
•Acceleration enrichment.
•Deceleration fuel cut.
•Cold start and Warm start compensation adjustment.
Data Logging
•Unlimited logging to laptop computer.
•User selectable ECU parameters to log.
http://www.trademe.co.nz/Browse/Listing ... =436916844
EMS 8860 motorsport ecu + loom (NEW)
speedracer_nz
speedracer_nz
