JZX100 Chaser Unfinished Project. Aftermarket Goodies galore
Posted: Sat Feb 18, 2017 5:25 pm
I havent worked on this this for3 years and have run out of places to store it. Grown up a bit with 2 kids. So buying a house is more important now. Will be sad to see mt dream go. IT the car on the right in the header up there ^^^^
Below is a list of all its upgrades and individual Resale value next to them if applicable. Its a bit of cash but its also a lot parts and work so far on a not so cheap car to start off with. To do this New from scratch through a shop. would cost 60-80k so this is cheap in comparison.
Can Supply photos of most parts and build process.
Half the parts have been ordered in from overseas or custom made.
1996 Toyota Chaser Tourer V JZX100 Series 1 Build Project
Reg on Hold. Certed for adjusties.
Front Suspension / Steering.
JZX110 Caster Arms with new Nolathane Bushings ($150)
Hardrace Inner Tie rod ends ($180)
JZX110 Outer tie rod ends ($100)
HeyMan PS800 Knuckles ($550)
30MM RCA (used) ($150)
CUSCO Adjustable Top Castor Arms ($600)
BC Gold Adjustable Suspension (Used) ($500)
Cusco Heavy Sway Bar ($350)
TRD Strut Brace ($250)
No Brakes.
TOTAL $2830
Rear Suspension/ Driveline
Hard Race Rear Traction Arms ($350
Hard Race Rear Toe Arms ($260)
Hard Race Rear Track Arm ($250)
Bc Gold adjustable Suspension ($500)
Kaaz 2 Way Diff 8” ($1200)
Braced and welded Subframe with solid RearDiff mounts. ($250)
Subframe Lock Collars. ($100)
Solid Front Diff Mount Collars. ($100)
Cusco Heavy Sway Bar. ($300)
Standard Tourer V Rear Brakes.
TOTAL $ 3310
Boot
Spare Wheel Well removed and drop box welded in for 60L Alloy Tank ($200)
Bosch 044 Lift Pump 255 LPH ($250)
Custom Surge Tank. ($200)
Fuel Lab prodigy Pump 400LPH ($600)
Fuel Lab in line Filter ($100)
Primed and Painted in Audi Lava Grey
TOTAL $1350
Body
Origin Lab Carbon Fibre Bonnett. ($900)
TRD Grill and Original Grill ($100)
Origin Lab Racing Line Front Bumper ($250)
Origin Line 6 piece 50mm Wide Body (front Fitted. Rear Tacked on needs fitting and small repair) $(450)
Origin Lab StreamLine Side Skirts $(250)
Total $1950
Interior.
Standard Dash and Carbon Trim
Knock off Bride Fixed Back Bucket ($250)
Hydraulic Handbrake
Key Delete and custom Switch Board
Total $250
Engine/DriveLine
Engine
264/272 HKS cams and asjustable cam gear $1500
Greddy Timing Belt - $ 200
Re shimmed Buckets.
Kelford Valve Springs and Titanium Retainers $300
New valve Stem Seals
New MLS Head Gasket.
New ARP Head Studs
Flowed Intake Ports.
New ARP End Cap Bolts
Front sump 1JZ Block and head with 170,000kms
All New seals.
Brand New Link g4 Extreme Wire In with Map sensor and Boost solenoid $2500 Pretty Sure Ive Got the Looms somewhere
Total $4500
Bolt Ons
Sinco T3 single entry Manifold. ($1200)
Custom Alloy Intake with 90mm throttle body, port matched ($500
Tial 44mm Wastegate ($600)
Tial 50mm BOV ($300)
Relocated Oil Filter block
Alloy Gilmour drives ($900)
TOMEi Fuel Pressure Reg ($100)
Custom Ignition Setup
Hardrace Engine Mounts ($100)
Custom Aircon Delete Bracket
100mm Intercooler
Oil Cooler
Moroso accusump and solonoids ($350)
Total $4050
Driveline
Custom machined Flywheel $(400)
ARP Flywheel Bolts.
Single plate 6 puk Carbon Kevlar 4300lb Clutchmasters Clutch ($800)
W58 Steel Sandwich plate 5 Speed Gearbox remote shift ($1500)
TOTAL $2700
Wheels
Lenso PDF 18x9.5 and 18x11 ($1500)
15mm and 25mm Bolt on Spacers
TOTAL $1500
Needs Braided hose/Hardline, Panelwork and Paint. Wiring(has been started but Was abandoned by sparky. Mini tubs finished. Small Bit of interior put together. Injectors, turbo, exhaust, Intercooler Piping. Front Brake. Windcreen. Cert. Majority of bolts tightening. Few Bolts Replaced.
Engine bay has had all holes welded and smoothed and Painted in Audi Lava Grey
Door Jams Painted with Audi Lava Grey. Have Enough paint to finish painting all high quality 2 pot.
Paint kit cost me $1500 and I Originally Paid $14000 for car.
Comes with personalised Plates “SWITCH” ($600)
Total price of parts if sold individually $23,040. This is Less than what I originally Paid
This doesn’t include paint, original car purchase, Small Items (such as seals and brackets etc)
Car owes me over 40k already. Just want to cut my losses I have run out of places to store it and need money for a house. 95% of parts brand new
Chuck another 10-15 k at it or less if you know what your upto and have one of the sickest chasers arouns.
Got shit loads of original Parts to go with it too. Bonnet, Gaurds, arms spare Diffs and axles.
22k ono.
No Brakes.
TOTAL $2830
TOTAL $ 3310
Boot
TOTAL $1350
Body
Total $1950
Interior.
Hydraulic Handbrake
Total $250
Engine/DriveLine
Engine
Re shimmed Buckets.
New ARP Head Studs
All New seals.
Total $4500
Bolt Ons
100mm Intercooler
Oil Cooler
Total $4050
Driveline
ARP Flywheel Bolts.
TOTAL $2700
Wheels
TOTAL $1500
22k ono.
