FS / EOI: JZX100 Mark II parts (manual)
~Slideways~
Re: FS / EOI: JZX100 Mark II parts (manual)
Post by ~Slideways~ »
JZ14 wrote:If they're Tourer V axles, I'm 1000% interested
1000%... that's pretty damn interested.
It's unconfirmed if its the big diff or not so I'll find out when I get it.
val
Post by val »
I am also interested in manual conv minus gearbox, i have a 1j and r1fiddy sitting in the garage.....
~Slideways~
OK the car has arrived.
FYI I am keeping the Engine, Gbox, ECU, Loom and possibly intercooler setup and some switches for windows and locks. So if there are other parts you need please let me know.
JZX100 Mark II face lift.
I'll put these parts on here for a few days before putting them on Trademe, so please let me know soon. I am in Wellington but can courier. I can only do it on weekends though.
BONNET:
Carbonfibre VERY light but needs repairs. $150 (Wellington only please)
Top has some clear coat damage and underneath frame needs some fibreglassing (I could fix the bottom).
If I was to keep it I'd remove the stickers and fill the clear coat damage then paint it and have a cheap and super light bonnet.
COILOVERS (two sets both suit 90 or 100)- $500 per set
TEIN SuperStreet coilovers, used condition no leaks. $500
TEIN - will check details when I take them off but look in same condition - $500
HEADLIGHTS Facelift - $100
Passenger good, Drivers missing a bracket
REARLIGHTS AND BOOT - FACELIFT - $150
Lights in great condition, missing driver indicator (its non facelift).
MANUAL PARTS - Very hard to get as you guys know. So very tempted to keep. $800 (no gbox)
Includes:
Pedal box
Crossmember
Driveshaft
Tourer V black centre console (for handbrake)
Handbrake
Handbrake Cables
Gear lever trim (Tourer V carbon, boot needs replacing but that's the easy part)
Clutch Master Cylinder
Brake Master Cylinder (unsure if different)
- There might be other small parts for the manual conversion that I don't need so please just ask.
REAR SUBFRAME
I need to pull it out and confirm if LSD or not, either its a super tight LSD or its welded.
FRONT STRUT BRACE: $100
Cusco
INTERIOR:
This is a converted non-tourer-v car so interior is not the black interior, but is in good condition so please just ask and I'll see if I have what you need.
I do have a spare Tourer V front seat, the complete back seat in tourer-v black trim)
ELECTRONICS:
Just ask and I'll check.
GLASS:
All there, offers if needed. Happy to get front screen removed professionally.
PANELS:
Two Spare front guards, $30 each
CHASSIS:
The Radiator support is slightly damaged but the chassis rails look perfect so I am happy to cut this up into anything you may need to repair accident damage. Or even the whole body?
gtivvl
Post by gtivvl »
keen on carbon manual trim how much?
ch4sernz
Post by ch4sernz »
Could be interested in diff depending on type
Whenever you get around to checking it
JZ14
Post by JZ14 »
Whats the diff code in it man?
~Slideways~
gtivvl wrote:keen on carbon manual trim how much?
Hey, for now I'd like to keep it as the listed 'manual package'.
~Slideways~
ch4sernz wrote:Could be interested in diff depending on type
Will let you know once I have it out.
~Slideways~
JZ14 wrote:Whats the diff code in it man?
Hi, I doubt its the original diff. It may have had a tourer-v subframe swapped in, so I need to take it out.
First thing I'll do is work out the ratio, then I'll take it apart and see what kind of diff it is.
Does anyone know if the rear brakes are bigger on the Tourer-V than lower models? The ones on this are the same big rears as my other tourer-v but since this is a swapped car, the fronts are still the smaller ones.
gtivvl
Post by gtivvl »
rear brakes dont change. tourer v have twin pots at front though. might be keen on front guards if they are mint and you can get them to auckland
