Bundle of JZX90/JZX100 goodies - On behalf
Looonie
Post by Looonie »
Hey guys, mate of mine has all this stuff for sale so I'm listing it on behalf.
JZX90 R154 Manual Conversion
Removed from 1993 Toyota Mark 2 JZX90 Imported from Japan. The car was standard with just over 130,000kms on the clock. Complete conversion including Interior Trims. Also includes the following items:
*New New Genuine Toyota Clutch Kit.
*New Custom Solid Urethane Gearbox Mount.
*New Red Line Heavy Shock Proof Oil.
*New Genuine Toyota Shifter Bush.
*New Drive Shaft Loop Kits x 2.
Selling as parting out some of my project car to free up some cash flow.
$3500.
JZX90 1JZ-GTE Engine Conversion
Removed from 1993 Toyota Mark 2 JZX90 Imported from Japan. The car was standard with just over 130,000kms on the clock. Complete conversion including Loom, ECU, Sensors and Accessories. Also includes the following items:
*New Genuine Toyota Water Pump & Backing Housing.
*New A/C Delete Drive Belt & Tensioner Pulley.
*New Thermostat.
*New NGK Spark Plugs.
*New Genuine Toyota Coil Plugs.
*New Rocker Cover Gaskets & Washers.
*New Oil Filter.
*New Fuchs 10w40 Synthetic Oil.
*New Cam & Crank Seals.
*New Pod Filter & Alloy Intake Piping kit.
*Cam Belt & Tensioner has been replaced recently.
$2500.
JZX90 / JZX100 HSD Coil Overs (NEW – Only test fitted)
*Come with extra uprated 18kg/mm2 & 14kg/mm2 springs.
*16 Way Adjustable.
$1500.
JZX90 Mark 2 Origin Made Full Body Kit (NEW)
$800.
Work Emotion XD9 17x8.5+42 & 17x9.5+44, 5x114.3 in Chrome
Fit flush with rolled and slightly flared guards on JZX90 Mark 2 with the below extras:
*215 45 Federal SS595 (NEW).
*Rears are junk Tyres.
*4 x 25mm 5x114.3 1.5TP Hub Centric Wheel Adaptors.
*4 x 60mm to 73mm Hub Centering Rings.
$1500.
AVS S5 5 Star Alarm & GPS Tracker + Extra Screamer Siren
*Latest models.
$600
Greddy Profec B Spec 2 Silver Electronic Boost Controller
Complete setup with equal length hosing and T pieces to control 1JZ-GTE Twin Turbo Setup. Less than one year old.
$400.
JZX90 Mark 2 Tourer V Full Interior
Excellent condition full interior including boot linings.
$500.
JZX90 / JZX100 Silk Road Coil Overs
Had them checked over and bottom bushes replaced. Excellent condition with adjustable height, pre load and damper front & rear.
$800.
JZX90 Glove Box Mounted Auto Gauge FLD Black face Water Temp, Oil Temp & Oil Pressure Gauges.
*Analog Stepper Motor Display.
*Extra Bright Blue Easy Read Digital Display.
*Warning Light.
$400.
Interested?
Call Matt on 021 288 6393
splatman1
Re: Bundle of JZX90/JZX100 goodies - On behalf
Post by splatman1 »
Would you sell boot lining seperate?
xMRWHIPPIEx
Post by xMRWHIPPIEx »
Hey man, do you have any pictures of the glovebox mounted gauge setup? cheers.
splatman1
Post by splatman1 »
What price would you take for both alarm and boost controller?
SEEN88
Post by SEEN88 »
Whatever happened to the Silk Road coilovers? I was bidding on them when the auction was withdrawn from Trade Me.
