FS- Supra 4 pot BBK, CT15 Turbo, Intake manifold, TB ++ More
luc3unitJZX
Post by luc3unitJZX »
Selling a few bits I have lying around after my build.
-Supra Front BBK with used pads, discs, offset nuts(to fit x90/100) and Rubber hoses.
-CT15 Factory 1jz VVti turbo. Had 180,000 kms on it. Bit of back and forth play. Didnt smoke when run.
-Factory 1jz intake manifold. No injector runner, no ICV. Be good for polish?
-Factory 1jz vvti throttle body, Traction control disabled
- 1jz VVti Exhaust manifold. Been modified to run top mount turbo with t3 single entry flange and 44mm Vband wastegate. Worked well.
- TRD Rear Muffler 3 inch entry. Has 2 bend to diff alreadly attached.
- 6 factory 1jz-gte VVTI injectors
All parts are for sale because they have been upgraded and surplus to my requirements.
PM or text 0223511223
Slammed
Re: FS- Supra 4 pot BBK, CT15 Turbo, Intake manifold, TB ++
Post by Slammed »
How much for the brake kit cheers
xMRWHIPPIEx
Post by xMRWHIPPIEx »
hey man, do you still have the brake kit?
