021 02240757
1994 JZX90 1JZGTE R154 Manual Mark 2
FRESH CERT
JZX90 front cut swapped engine and gearbox
BC Gold coilovers
Hardrace toe
Hardrace camber
Cat back Stainless 3.5 inch exhaust
Front mount intercooler
50mm Alloy radiator
Thermo switched dual electric fans
Walbro fuel pump
Engine seals serviced (cambelt waterpump etc)
Chromolly flywheel
Autoclutch Clutch 6 puck 4000psi
Cusco strut brace
Znoelli slotted and cross drilled rotors
SP 5000 pads
Rebuilt calipers
Stainless steel brake lines
New Toyota A arms (F)
Driveshaft hoops
R33 Gtr wheels
Brand new windscreen
Fresh wrap in Avery high grade vinyl (original car colour is metallic black)
Have a KW bucket seat and rail it can come with for extra
Cons:
Tacho isn't wired up (digi dash)
Its a 20 year old car so don't expect a Bentley
Waiting for cert plate to arrive
