16 way adjustable
Separate height and spring preload adjustment
10k front and 8k rear springs
No leaks, I stripped them all down to check for any signs of leaking or weak damping but all are sweet. Some slight chips in the paint around the bottom mounts due to fitment and height adjustments but otherwise they're in good condition.
They come with pillowball top hats but I've fitted standard tops to the front and slightly modified the way the rear shock tube bolts to the top hat.
I'm after $650
