!!1970 toyota crown!!
Re: !!1970 toyota crown!!
ROAR!! MIIINEEE !!! ROOOAAAAARRRR!!!!
you are sure?
its either that or a ms4* series what yr exactly is it?
as i said im not 100% sure at this stage
but its a 1970 and is a classic now aswal
im just wateing to hear back from my cuzen with more details
about it,
i dont realy no to much about crowns but soon as i get photos thay
will b strate on hear.
iv seen it heaps but coz not nowing much about them
i wouldint have any idea of the details of it.
about it,
The year tells me its a 40 seriesFLAWLES wrote:you are sure?
would be lush if it was a 40 or 50 seriesryanfels wrote:The year tells me its a 40 seriesFLAWLES wrote:you are sure?
but my 55 was regoed as a 1970 so pending on where or when it was made/imported would make or break it
i herd a rumor once that ozzy bulit ms55 had drum front end while the jdm ones had disc?
man i want a ms55 again
so ended up buying this , was really happy , still am but kind of gutted at the same time
looked at the car pretty well , and on first inspection looked mint as
so there was an area in primer on the rear quarter ,I asked what had happened here and was told it was backed into in a carpark and don't worry it was all repaired properly, thats where i'm gutted looks like bog has just been smoothed on over some pretty bad rust ,
after grinding it back to see how bad it really is
and the rust has spread to the spare wheel well
far from "mint" , going to cost over a grand to fix , I'm still happy that I got the crown but a bit blown away by the rust and how much its going to cost to just get it wofable because of the rust. Guess you could say I should have looked harder but I did look this over really well looked like a well done repair, even the spare wheel well had undersell over all that rust had to really hack it away to see it
