Just sorting a group buy with some mates at the moment for HSD JZX coilovers. Will have a spare set available if anybody is keen for cost price. Otherwise I will put them up on Trademe- RRP is $1600.
$1250 is cheaper than wholesale trade price!
These come with 15kg fr/8kg rr & are full adjustable damper/height etc etc. Great for street & track/drift. Just fitted some to a JZX110 & excelent range of damper- nice & plush for street & can be hardened up plenty for some track or hard driving.
Let me know asap if you want to join in. Could actually get other variations if that helps too (i.e S13, Supra, etc, etc) We are just all getting JZX90/100 ones. Nothing oldschool sorry- AE86 etc are higher cost, but could prob get a deal.
HSD Coilovers suit JZX90/100 brand new in box $1250
Brendan,
Convert Ltd/Niteparts NZ
- twojayzeejza
Re: HSD Coilovers suit JZX90/100 brand new in box $1250
What sort of price on the jza80 brendan.? Oh and are they camber adjustment too ?
Toyota Supra JZA80 1996 manual turbo
Same price Dam cheap! None of them will be camber adjustable as the camber is adjusted through the alignment cambolts from factory (or though aftermarket arms) on JZXs & JZAs etc rather than strut tops like old toyotas.
Ive always found good factory adjustment on the big toyotas. Just the rear can toe in alot if you really slam them but plenty toe arms available nowadays.
Brendan,
Get you get them for the JZS161 Aristo's?? could be keen if you can...cheers
Pretty sure I can! I can check stock tomorrow if you like. I have driven a set fitted to a JZS161 before & they were primo ride- went dam low too.
They will be same price too
Brendan,
- twojayzeejza
Im in for some jza80 ones brendan
No problem. Looks like we will do it later this week then. Will PM those who are in.
Brendan,
if you can still get these, im wondering if you can get them with a spring rate of around 20kg front, and 18kg rear? cheers
Hey, can still do them if required. Not quite at $1250 unless I get another 5 parties interested.
Can do up to 18kg springs on special order, these kits normally come with 12/8 but can do 14/10 for track/hard street.
20/18 in a JZX is full D1 spec rates~?! Our test JZX100 is running 14/10 at the moment for track & street use & its primo. We are putting some more weight into it & moving to 16/12, but its mainly track use.
Brendan,
