Hi Everyone,
As these forums are brand new there are bound to be some changes that are going to need to be made. At this point in time I am clueless to what needs to be changed as we haven't used the forums much yet but I'm sure as time goes on, things that need to be changed will be noticed. Please let us know any suggestions that you may have here.
Chur
Forum Changes Discussion
Re: Forum Changes Discussion
Application process would be good, so that it stops potential thieves / lurkers etc.
- scotty_ish
Can't use pictures as a signature?
quick reply box in some areas
So far these are pretty easy changes, we'll build a list over the next couple of weeks before I make changes though.
What sort of application process do you mean? We could have the members cars thread more private, such as only to people who have registered on the forums.Sam wrote:Application process would be good, so that it stops potential thieves / lurkers etc.
you have to fill out an application form with details about yourself (kinda like new member's section) but then there is a poll and the rest of the members that are already there can vote if they want you in or not. basically you need a vouch by someone inside so that they can say you are all good and not some hoodrat thug scum. it sounds elitist but it keeps the community very close knit.
maybe a section with model information for newbies (and me) about the good points and potential problems of some of the jzx models such as the dreaded twin turbo problems on some cars.... just a thought
that would be covered in the tech section once the forum gets up and running etcjohnny5 wrote:maybe a section with model information for newbies (and me) about the good points and potential problems of some of the jzx models such as the dreaded twin turbo problems on some cars.... just a thought
a dedicated moderator group would be nice
- scotty_ish
When you click on a link it would be nice if it opened a new tab rather than navigating away from the forum
maybe something to auto resize oversize pics?
