Another thing is every time i go side way
PLEASE HELP!!!
THANKS!!
May i ask where do you found the srs wire? or which wire you hotwire. please let me know, lol. because really ........i need to pass the test...........i think pass the test and then slowy fix it when i have time. want to pass the test first.shweatypox wrote:Although I don't think it's good to doon another car I rewired the SRS light to the engine check light, that way it shows up when the car is on and switches off when the car starts. Got it through the WOF test
You need to remove the instrument panel, then all I did was run wires from the Check Engine light and connected to the SRS bulb. Was easy in the Mitsi Lancer I did it on, not sure about a JZXperentti wrote:May i ask where do you found the srs wire? or which wire you hotwire. please let me know, lol. because really ........i need to pass the test...........i think pass the test and then slowy fix it when i have time. want to pass the test first.shweatypox wrote:Although I don't think it's good to doon another car I rewired the SRS light to the engine check light, that way it shows up when the car is on and switches off when the car starts. Got it through the WOF test
