Manual parts
General discussion
driftouteast
Manual parts
Post by driftouteast »
Anyone know if these would suit a jzx100?
http://www.trademe.co.nz/motors/car-par ... 808745.htm
gtivvl
Re: Manual parts
Post by gtivvl »
bit pricey for some pedals, x member and a driveshaft. dont think they would suit x100 though
FLAWLES
Re: Manual parts
Post by FLAWLES »
i think you can use everything but the drive shaft as its either longer or shorter.... but i know the mounts are slightly at different heights
also pends if its from a jza70 or 80
Looonie
Re: Manual parts
Post by Looonie »
FLAWLES wrote:i think you can use everything but the drive shaft as its either longer or shorter.... but i know the mounts are slightly at different heights
Neither.
Looking at that driveshaft, I'm picking GA61 Supra/Celica bits.
