the coil plugs on my 2jzgte have all fallen to bits on the inside and im after some replacement ones, the plug on the loom side
anyone got any?
where to find replacement coil pack plugs
- twojayzeejza
Re: where to find replacement coil pack plugs
there is a company up north called dasko
they do a wide ange of everything automotive electrical, and are very very good esp if you need replacment coil packs you can give them a bell and see what they have
0508 432 756
you have to have a trade acc with them tho to get the goods ( if they have it ), if thats the case let e know and i will purchase them for you
failing that im sure toyota do them as a spare part
0508 432 756
I deal with dasko regularly, for tractor stuff like flawles.
very good company to deal with.
Also have account with them and live just around the corner.
Logan
Logan
