Altezza lsd. Will it fit?
General discussion
x90
Post by x90 »
A01B 4.1 Torsen LSD, will it fit my jzx100?
phys
Re: Altezza lsd. Will it fit?
Post by phys »
Pretty sure the altezza have a 7.5 diff not an 8?
I am no expert but I don't think it will and shaft size will differ too.
Take that as a view/belief of a complete newb.
Is your JZX100 factory turbo?
x90
Post by x90 »
non turbo factory and still non turbo, yes altezza crown wheel is 7.5inch
Mike
Post by Mike »
hmmm, i should fit, i think only the turbo ones has the 8" crown
some of the auto stuff roll the same centres
SXE10, GXE10, JCE15W · GXE10W
2JZ-GE、1G-FE 2JZ-GE, 1G-FE
= trd lsd 41301-se100
JZX90/JZX100 (4A / T cars) · 105 1JZ-GE
clutch type lsd
2jzge and 1jzgte x90s and 100s have different lsd centers same with 3sge sxe10 tezzas ( i think )
blink13b
Post by blink13b »
FLAWLES wrote:some of the auto stuff roll the same centres
clutch type lsd
so just to clarify, i have a jzx100 avante 1jzge auto, what factory altezza should i go for, coz im sick of this single spinner, its the only vehicle i own with an open diff, i remember why i hate them!! got to get it sorted, let me know what will fit, part numbers etc would be awsome. cheers
jzx = yes........ anything else = no
xnickx
Post by xnickx »
Throw me your chassis/frame number and I can give you a definite answer.
The 5AT non turbos (gated shifter) ones still use the 8.0" diff centre, the 4AT non turbos have the 7.5" centre.
Either way you'd need to swap just the centre, you wouldn't be able to use the 4.1:1 crowngear with your current pinion unless you have the complete diff head which (if it is the same A-Series 7.5" centre) should bolt in.
Check on your chassis tag, if it starts with a Bxxx it's the 8.0", if it starts with Axxx, it's the 7.5" diff.
Might have a shimmed up torsen A01B kicking around in a few weeks if yours turns out to be the 7.5" centre.
nite b
Post by nite b »
The altezza torsen lsd unit will fit into the gx90/100 diffheads. They are the smaller ones with 4 bolt driveshafts from memory. Pretty sure they wont work on the small & large 6 bolt heads though.
Brendan,
Convert Ltd/Niteparts NZ
blink13b
Post by blink13b »
ok cool, yeah mine runs the a340 trans, (non gated) so it should be the 7.5'' diff.
could be keen on that shimmed a01b diff, is it just the centre, or the whole assy?
