Radiator Top Tank Browning + Coolant Change Q's
Posted: Mon May 09, 2011 7:52 pm
Hey Team,
I've had the JZX100 for nearly 8 months now and the radiator has always had a brownish coloured top tank. I'm planning on doing a few more power mods in the following months and perhaps beating it around a track day or two. The only thing I am a little worried about is the radiator. I've heard lots of stories of people having the dreadded discoloured 'brown' top tank which is prone to cracking yet there's been no evidence from anyone who has had one crack/leak from it.
Can anybody confirm whether this myth is true or if it's just UV damage which has worn the paint off?
Also, a coolant change is in order soon so is it a requirement to use genuine 'Red' Toyota coolant, or can I just use the standard anti boil green stuff?
Ta,
Phil
Re: Radiator Top Tank Browning + Coolant Change Q's
Posted: Mon May 09, 2011 8:00 pm
Just had a look on JZX100 Forums and i've found an answer about the Coolant. The green alternative coolant is alot more corrosive which can cause all sorts of issues with the alloy block.
Will be seeing you for some coolant Pete
Also, does anyone on the forum work in the Radiator industry? Wouldn't mind getting a replacement unit priced up if it's best for me to replace the radiator and I don't want a cheap crap aluminium one if the oem one does a better job at a better price + I would like to keep the viscous fan and shroud.
Posted: Mon May 09, 2011 8:43 pm
by Looonie
Tofu wrote:Just had a look on JZX100 Forums and i've found an answer about the Coolant. The green alternative coolant is alot more corrosive which can cause all sorts of issues with the alloy block.
Give Jason a ring, he'll sort you out happier than a schoolboy with a lifetime supply of lube.
And Toyota red FTMFW.
Posted: Mon May 09, 2011 8:49 pm
Looonie wrote:Give Jason a ring, he'll sort you out happier than a schoolboy with a lifetime supply of lube.
Sounds kinda fun. Haha!
Thanks Dave. You're meaning TOYWGN/Jason? If so, i'll get in touch with him,
Ta,
Posted: Tue May 10, 2011 8:27 pm
by Looonie
Tofu wrote:Looonie wrote:Give Jason a ring, he'll sort you out happier than a schoolboy with a lifetime supply of lube.
Ta,
Indeedlydoo.
Posted: Tue May 10, 2011 8:47 pm
by speedracer_nz
yip jason will be able to tell you hes done more radiators then i have had hot dinners, btw my top tank cracked on the 91 from just being old, it showed signs of cracking way before it leaked though
Posted: Wed May 11, 2011 8:58 pm
by han16
Oh dam, same engine - same issue with my radiator here.
As the Mark 4 supra uses the same rad I can just pick up an alloy one for my Soarer, which is planned for after the paint work and before any sort of turbo upgrade to the 1JZ. No idea if its the same on a jzx?
Posted: Thu May 12, 2011 10:43 am
by murdoko
i always use 'toyota red'...
