It is currently Sat Dec 22, 2018 11:29 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: jzx81 chassis-what r154?
PostPosted: Sun Apr 17, 2016 1:37 pm
Offline
Hello to the jzx community.
If i was floating the idea of putting a manual gearbox in, what version of R154 fits? is there just two versions, standard, and remote shift?
The car is a LX80 (sedan), with a jzx81 crossmember in it, to fit the 2jzgte. The rear diff and axles were tiny,so have fitted a hiace rear axle with tightened hilux LSD.
_________________
1989 2jzx81 mark II project.
Top
 Profile
PostPosted: Thu Apr 21, 2016 2:16 pm
Offline
man this forum seems pretty dead recently, has Facebook sucked the life out of it, like most other forums??? :(
(you can probably tell i don't do Facebook...)
_________________
Top
 Profile
PostPosted: Thu Apr 21, 2016 7:08 pm
Offline
Unfortunately yes. I refuse to use FB or any similar site.
viewtopic.php?f=30&t=854
This topic might help you a bit, however since JZX81 never came with MT from factory, im fairly sure you are looking for a non remote shift R154 from a JZA70 supra. You also need to mod the transmission tunnel as its only made to fit the W series boxes.
Top
 Profile
PostPosted: Sat Apr 23, 2016 9:58 am
Offline
hey thanks for the reply. I didn't know that the jzx81 never came with a manual trans option.( But i thought that they would be fairly rare , like a manual soarer.)
_________________
Top
 Profile
PostPosted: Mon Apr 25, 2016 2:52 pm
Offline
Im not on fb either :D
I thought jzx81 was offered factory manual option with 1JZGTE + R154, but the 1JZGE was auto only.
Like m989 says same shifter position as JZA70.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
