1jz gte turbo
1jz gte turbo
Hey has anemone got a second hand turbo set up with manifold turbos lines etc. Is it easy to plus t these? I'm new to 1jz but have done a lot with Rb. Any help would be appreciated. Also any turbo engines for sale? Even a rebuild job I'm keen
- Driftmonkey
Re: 1jz gte turbo
If you're looking to plus t a 1JZ-GE, no luck bud. Or from what I know atleast. The non turbo have a different exhaust manifold pattern to the 1JZ-GTE so a turbo manifold wouldn't fit unless it was specifically for a plus t setup which is rare because the 1J turbo engine is cheap enough.
Re: 1jz gte turbo
waste of time, totaly different engine, just get a 1jzgte, your not dealing with rbs now forget what you know
Re: 1jz gte turbo
There are manifolds available at a large cost to NA-T them all depending on budget but the ECU is where the cost is. It's cheaper by a long shot to buy a front cut and convert the lot over
