Coils for jzx110
General discussion
Slammed
Coils for jzx110
Post by Slammed »
Can a jZx 100 adjustable coils fit a jzx110 if nt does. Any body hav a set going below cost price cheers
Re: Coils for jzx110
Post by shweatypox »
Whenever I see BC golds or anything on TradeMe it always states they will suit the 90/100 and 110 but I'm not sure
archon
Post by archon »
Fronts fit, rears won't. Altezza coilovers fit.
The only way you'll get any below cost is go to Autolign and stick a set of TEINs up your shirt.
Post by davealdworth »
As said above the altezza gear bolts directly up and there are some options for the GS300 or Aristo whatver you want to call it that will suit it too and the they come with the spring set up for the heavier car. A good cheap option that alot of the japs run is Largus, they put them on everything that needs to be streetable and trackable. Cheap and reliable
