jzx100 wheels
jzx100 wheels
Does anyone know front +18 9'wide, rear +18 10" wide will fit into jzx100 chaser?
Re: jzx100 wheels
F. 9J @ 18p will be fine on the front, you'll need to maybe roll the front guards and run a tyres like a 225/40. I run a 9J @ 15p with a 225/40 up front and it fits fine.
R. 10J @ 18p will fit as well. Will be tight and you'll definitely need to roll the rears if you're running stock rear arms. I wouldn't go wider than a 235/40
Re: jzx100 wheels
Im running 18x9.5 with a 15p all round on mine with 225 40's. Only had to lip the rear guards and the front sorts it self out if your running it that low
Re: jzx100 wheels
Thanks for your help guys
