Page 8 of 18
Re: What did you do to your x chassis today
Posted: Mon Oct 29, 2012 8:54 pm
by JZX90LOVE424
Got me a new one
Posted: Tue Oct 30, 2012 12:27 pm
by lofreq
last saturday i spent 10minutes with a drawing pin adjusting the little window squirter nozzles so that they now shoot perfect "V" streams on each side of the window.
Posted: Fri Nov 02, 2012 11:19 pm
by luc3unitJZX
Bit a kerb. 5 up in the car, wouldnt switch and bit some crete. Damage as of so far. 1 rim, 1 tyre, 1 lower arm, 1 cusco swaybar, 1 rear tourer V lip. Questions. What is the lower arm furthest to the back that the sway bar link attaches to?? And does anone know where to source a rear tourer V lip. Mines sadly in 3 pieces
Posted: Sat Nov 03, 2012 3:31 am
luc3unitJZX wrote:What is the lower arm furthest to the back that the sway bar link attaches to??
Lower arms are what the swaybar links attach to. You might as well use this as an opportunity to buy aftermarket ones, pretty sure North Shore Toyota sells camber adjustable lower arms. They do Cusco swaybars too so that's basically half your problem solved... just add $$$
Posted: Sat Nov 03, 2012 10:36 am
theres a jzx100 sitting in pick a part hamilton...........go steal the sub frame
Posted: Sat Nov 03, 2012 11:31 am
by ohyeahjake
FLAWLES wrote:theres a jzx100 sitting in pick a part hamilton...........go steal the sub frame
Looks like I am going to do a trip to Hamilton today
Posted: Mon Nov 05, 2012 7:33 pm
by luc3unitJZX
Sorted the arms out, Was the control arm that was bent. Went and got a set of hardrace adjustables for it. Rear lips munted. Anyone have a Tourer V rear bumper lip they wanna part with?
Posted: Thu Nov 08, 2012 7:46 pm
by murdoko
Scored on a set of cusco chassis braces 4pt and 5pt at tparts! Out goes the UR braces... yes! Tparts has a few x100 and x90s so might pay to ring them up....
Posted: Fri Nov 09, 2012 1:45 pm
by HeapsThorn
What else do they have??
Posted: Sat Jan 12, 2013 9:41 pm
by Shimmy
Adjusted the ride height 10mm higher sadly so I can get in my crap driveway. Did the wheel alignment at work only to find two of the camber adjusting bolts at the rear are spinning inside the oval washers. Managed to get the toe correct but have to settle for 4 degrees of negative camber till I weld the washers to the bolts next week. Oh well looks mean!
