jzx90 manual clutch pedal alternatives???
General discussion
kramer
Post by kramer »
hay there
just wondering if anyone knows of alternative clutch pedals that can be bolted into or easily modified to fit a jzx90 mark 2. planning on using an r154 ath this stage
any ideas??
cheers
kramer
speedracer_nz
Re: jzx90 manual clutch pedal alternatives???
Post by speedracer_nz »
you could use a wilwood or tilton firewall mount single pedal, pretty cheap and depends how much work you wanna do really. not that hard to fit
FLAWLES
Post by FLAWLES »
ee101 pedal box's are dam close
just have to drill one extra hole
dom
Moderator
Moderator
Post by dom »
x100 clutch pedal :P
kramer
Post by kramer »
awesome thanks guys, where would you source wilwood or tilton firewall mount pedals?
speedracer_nz
cardwells in nz or usa, often on ebay they can be had for cheap in the u.s
FLAWLES
Post by FLAWLES »
dom wrote:x100 clutch pedal :P
fully
try your luck with genuine toyota parts you may just be suprised
bracket
55107-22170
pedal
31301-22260
just two of the many parts
speedracer_nz
even try yahoo japan, im not to sure of there shipping issues there at the moment. Could get bits air freighted over quite cheap provided all of lower japan is still in working order.
Mike
Post by Mike »
try gx feints on here, he has a brake and clutch pedal and line for 200, cant really beat that
kramer
Post by kramer »
sweet fellas, have pm's gx feints bout his setup. hopefully he still has it. otherwise good advice from everyone else, thanks heaps.
on another note, wonder how many jdm goodness parts\suppliers were destroyed in japan?
